81 - 98 of 98 Posts
i sourced online and pretty easy to connect to F can as well ,to be honest you can get away with out tapping F can (IMHO) .you would need a tuner if you truly want to get HD radio and gps antenna.I do have the cables ready to as i removed radio and sold almost all the parts .still have the cables with me that i made for this project .Hopefully someone can make use of ;)
@shadethegrey What was the biggest hurdle with this project? I remember a while back, you mentioned issues with codes. Im looking to do this to my 14 6-6 and replace the factory speakers with richer sounding ones. Also, to install the Ktuner app
no hurdle at all , unlock codes list is long, you just need to keep it connected to a bench power supply and try every 60 minutes until you get the right one it only took me 8 tries before the right code was accepted by radio.
Are you selling your harness? I just bought a 2017 radio for cheap
I wouldn't mind building one. If you could help me do that we could post all the details as we go as there's probably others who'd like to do it too. I spent a lot of time looking into this project a few months ago, as you can see if you scroll back a few pages. Never was able to map every wire I needed, don't recall the details right now. I still have the upper i-Mid screen in a box as I received it from eBay!
My car is a 2014 EX-L Hybrid if that helps. What is yours @creamridge ?
Does anyone know where I can find a GPS cable. I bought the antenna itself, but apparently I still need the cable to go along with it. Either that or what kind of connector it is so I can get it from Mouser.
Fakra connectors, there are already premade cables out there, just make sure you get the proper plug type.
Found a GPS antenna that should have the correct connector. I have three things left on my list. I need wire locations for the bluetooth mic at the hfl module, location of the f-can system if I ever want to hook them up, and the compass wires, if they exist.
Compass uses GPS antenna installed somewhere behind top screen. You should already have the GPS antenna if your trim is ex and above.
wire location of bluetooth is in the panel behind front passenger door side.Fcan is 2 wires that are on anc module right under the radio,you would need to tap into the 2 wires,i did not have any benefit of fcan IMHO.compass is a different topic as that module is missing in mine gps will give substitute compass i think.
98% sure they're the same. 2016 was the changeover. So you made a plug and play harness and had everything working?
yes i had full functionality with my retrofit,with exception that imid MPG did not match as radio came from a coupe not hybrid and rear camera was off .pretty sure this is programmed into radio.
Mpg display is not a deal breaker ,camera is a big deal as it was pointing to the sky,coupe camera orientation i guess.
i would say its a 100% retrofit if you get a 2016/2017 hybrid radio.the radio i sold was rooted as well to use waze, netfilx etc.if you are inclined and have time its worth doing this retrofit ;)
You wouldn't happen to know the wire colors involved for the mic? I know you can get the wires at the HFL module under the radio, but I cant find out which is which.
My post #27 in this thread has pictures of the back of both radios and wiring diagrams.
Could you describe the harness you built in terms of the connectors as they're labeled there (which is Honda's labeling scheme) where each connector has a letter assigned to it, i.e. the A connector or harness, I think Metra sells one. JAE MX34 describes a series of connectors, can you give specific part numbers for any connectors you used?
81 - 98 of 98 Posts
