1 - 8 of 8 Posts
Angielyn
is this seem right for 2017 accord exl? Never had any issues with it i know its suppose to be around half way ,but seems lower to me . I've checked fluid all good. Is this a normal range if it stays in one place after warming up? Thank you. Sorry if this seems silly to ask just genuinely curious.
That is coolant temperature, not coolant level. Yes, it's normal for Honda coolant temperature stays at ~40% of the gauge, after warming up.
Thank you,maybe I mis spoke but I did mean temp gauge. That's why I was asking ,I new it was suppose to be in the middle of gauge ,as long as not near Hot or to cool,but it seemed lower than . My tank under the hood levels are fine. Thank you
Reactions: Angielyn
Mine has been ,( a little lower) like yours for 365,000 miles , your good.
The temperature gauge has 3 settings, cold, normal & hot. If it goes slightly above the usual setting or half way it is still in the normal range. If you really want to chart your engine's coolant temperature then get a scan gauge.
1 - 8 of 8 Posts
