Just remove the undercover to access the drain, then refill to the fill hole level. Replace the washer on the drain plug. Numbers by the fastener are torque specs. Last # is ft-lbs.
Can you possibly share the document for changing transmission fluid of our 10th gen Accord hybrid?
My own car is hitting 33k miles after 1 year of use, and I expect to do this at 40k miles.
Thanks!
Very helpful information, thank you!View attachment 532432
You’re welcome.Very helpful information, thank you!
This is way easier than any AT fluid change and almost as straightforward as changing MT fluid.
I guess the fluid isn’t doing much job inside this case, other than engaging/decoupling the clutch. Motors don’t need transmission fluid as is the case for all EV.
I
I wasn’t informed ahead of time of a premium vrs non premium type of service. It only came up in conversation with the parts guys as I questioned whether Honda DW-1 was a FULL synthetic product as well that they were mixing it with on the partial change. I never got the price diff on service just that the MAG1 fluid was like 18$ a quart compared to 12$ for the OEM??
Anyways there’s no argument on my part about keeping fluid clean! But it did surprise me using in aftermarket fluid along with conditioner plus I was charged for 4 quarts of the MAG1 and the bottle of conditioner 12 oz I’m guessing on the drain and refill. Which according to the manual is 2.3 quarts 😳 question is where’d they put it? = not happy 😞. BTW this fluid is available on Amazon for 6$ a quart shipped 😩. Take a look at the receipt where they show it at 27$ but sell it to me for 18$. I think “stealer” rather then “dealer” certainly applies here and for this customer anyway will NEVER happen again.
I have a 2020 Hybrid Touring currently at the dealer for a defective "Transmission Cooler"...not sure what that is but I found coolant all over the engine compartment, radiator and dripping under car. We only have 1,400 miles on it after only owning it for 6 weeks. Did I get a lemon or part of bigger issue with design?Interesting because I have yet to hear about the hybrids having any transmission problems whatsoever (please don't turn this into another ridiculous "well it doesn't have a tranny debate") that would cause them to add the extra protection. There's nothing wrong with this type of additive. I'm more familiar with different companies versions but basically all the same. Usually they are used in race or higher hp/heat applications. They definitely help reduce friction and therefore temps ect and work.
The question at hand here is how much extra did the dealership charge for a $15-20 can of additive compared to the non premium service.
Sounds like it's just leaking on the coolant side, probably just a bad part but can't hurt to ask and document it.I have a 2020 Hybrid Touring currently at the dealer for a defective "Transmission Cooler"...not sure what that is but I found coolant all over the engine compartment, radiator and dripping under car. We only have 1,400 miles on it after only owning it for 6 weeks. Did I get a lemon or part of bigger issue with design?
There is no coolant for transmission. Two reservoirs, one for engine, the other for inverter. Which reservoir did you see fluid loss?I have a 2020 Hybrid Touring currently at the dealer for a defective "Transmission Cooler"...not sure what that is but I found coolant all over the engine compartment, radiator and dripping under car. We only have 1,400 miles on it after only owning it for 6 weeks. Did I get a lemon or part of bigger issue with design?
Does it use engine cooling system to cool the CVT like Nissan did?There is no coolant for transmission. Two reservoirs, one for engine, the other for inverter. Which reservoir did you see fluid loss?
I don’t know exactly. Based on what I know, there isn’t many components inside the ‘e-CVT’ transmission cases, so the fluid is mainly for splash lubrication plus one job — controlling the direct gear.Does it use engine cooling system to cool the CVT like Nissan did?
No eCTV cooling except the several qts of DW-1 in it. Thank goodness it’s not built like a Nissan(Jatco) CVT or I wouldn’t have bought one! As Ziyang mentioned, two individual separate systems. One for the ICE, one for inverter. @HighlandChris Most likely it’s the inverter cooler because its above the e-CVT.Does it use engine cooling system to cool the CVT like Nissan did?
Hi @Hunter Mike I am collecting tools and parts for the transmission fluid change these days. The major question I have now is the two plugs' washer size. Can you possibly let me know what size washers to buy for the transmission fill/drain plug?View attachment 532432
Honda used to use a 18mm on the ATF drain but I’m not sure if it’s the same. P/N 90471-PX4-000 was what I used on my ‘14.Hi @Hunter Mike I am collecting tools and parts for the transmission fluid change these days. The major question I have now is the two plugs' washer size. Can you possibly let me know what size washers to buy for the transmission fill/drain plug?
From what I can find online, the drain plug seems to have 20mm washer; the fill plug is 10mm. It would be great if you can verify these!
Some might suggest that the dealer will sell me with correct parts. No they don't. Last time I went to a dealership parts store and asked for the washer for my 2017 Civic 1.5T 6MT transmission drain plug, but they sold me a wrong sized one which seriously interrupted my transmission fluid change job...
Thanks! I think I also checked a similar photo but probably that was from an incorrect model.Honda used to use a 18mm on the ATF drain but I’m not sure if it’s the same. P/N 90471-PX4-000 was what I used on my ‘14.
A quick look shows the same part listed for the hybrid drain plug. AT Flywheel Case - 2021 Honda Accord Hybrid 4 Door EXL KA CVT
I may be violating the recommended procedure but I have never changed a crush washer on a engine or transmission and never had a leak. The threads do their job and IMHO the old washer will also.Thanks! I think I also checked a similar photo but probably that was from an incorrect model.
So in addition to the 18mm drain plug, the check hole would need 10mm washer, is that correct?
Looks like it for the check hole.Thanks! I think I also checked a similar photo but probably that was from an incorrect model.
Let me guess, you don’t use a torque wrench either?I may be violating the recommended procedure but I have never changed a crush washer on a engine or transmission and never had a leak. The threads do their job and IMHO the old washer will also.
I am in my upper 50’s and have always changed my own oil and services lots of Honda transmissions over the years. Never have a leak and no I don’t use a torque wrench. Done enough to know what’s right and what’s not. And kept my 97 civic for 18 years and never an oil or trans plug leak.I recommend and always use a new sealing washer where specified, but it's technically just that - a sealing washer and not a crush washer.![]()
That it is. It just does the job of sealing by crushing.I recommend and always use a new sealing washer where specified, but it's technically just that - a sealing washer and not a crush washer.![]()
Appreciate your details and it really should go top of this hybrid Accord sub-forum for everybody!I just changed mine today in my ‘21 HAH.
Flat-head screwdriver and phillips to remove the belly pan. 17mm socket to remove the check bolt, 3/8” drive to remove the drain bolt. The fill is up top behind the radiator and it’s just a rubber plug with an ‘L’-shaped wire to pull it out.
18mm sealing washer on the drain, but the check bolt is a bit larger. I didn’t measure and re-used the existing one. 19mm or 20mm because it wasn’t much bigger than the 18mm I have on hand. 36lb-ft on the drain plug, 32lb-ft for the fill.
Took about 2qts, 8oz. to fill so you’ll need 3qts on hand. I used a funnel with a short rubber hose extension. Don’t install the check bolt until you fill and it’s dripping out.
It took about a half hour but future changes will take about half that.
I found the fill hole looking underneath and I saw this short angled hook pointing out. It came out easy and it’s just like a stopper in a bottle.Appreciate your details and it really should go top of this hybrid Accord sub-forum for everybody!
I’m surprised that you mentioned another ‘fill port’ since I was expecting to pump fluid back through that check hole…
How many miles was there for this fluid change? Does the old fluid look alright? Do you plan to send it for analysis? Please keep us updated, Thanks!
