1 - 7 of 7 Posts
Hi guys,
Tried searching around for answers to my two questions but didn't really get anywhere. Hopefully someone can help me out:
I live up in Northern British Columbia where we tend to get some heavy snowfall and this will be my first winter with the coupe.
My first question is: Is it ok to go to 205-65-r16's from the current 235-45-r18's? (I got the size from tirerack.com)
My second question is: I'm going to need TPMS and was wondering if these:
http://cgi.ebay.ca/2008-10-Honda-Accord-Tire-Sensors-Set-4-TPMS-CRV-/290486018482?pt=Motors_Car_Truck_Parts_Accessories&hash=item43a250e1b2
would work fine? They seem to be generic but i'm on a budget and would love it if i could get these rather than spending $200 at the Honda service desk or at the shop that I will eventually get my tires from.
Help would be much appreciated.
Thanks guys.
are you going to be getting an extra set of rims?
Cause the tire size you put down is for 16's.
yes will be going to 16" steelies. do you see any problems with the sizing? Also, is there a difference between the size of the coupe and sedan brakes?
Doc Mojo
you should be fine with the tire sizes. for my winters, i go 1 width narrower and 1 profile higher without changing my rim diameter.
you can see the changes here:
http://www.1010tires.com/tiresizecalculator.asp
comment about TPMS:
if you don't get a TPMS reset tool ($150 ish), you would have to get it reset at the dealer/any shop for about $40 each time you switch your setups. Tho i should have done it (i didn't, but i did it with my DRL warning light), you could take out your instrument panel and tape a black electrical tape over the TPMS LED light. You're suppose to check your tires often anyways, TPMS lets you sleep easier knowing it's there.
you could just use the LX line tire size 215/60/16 with OEM replacement steel rims . 205 is a little on skinny side IMO for 3400lb car .
lol i use 245/45/17s on my winters =D dont ask me why so wide, the reason why i used wide tires is because i have a 1inch drop but i drive a sedan so who cares =D
What decided me on the tire size for my winter tires (215/60-16)... is the price.
I quoted tires on the OEM size on my car (225/50-17) - Michelin xIce2 --> 285$C each. Can you say Ouch?
The I asked the price of the same in 215/60-16: 182$C. 16" steelies? 45$ each.
Conclusion: 280$ saved (with taxes). With a second set of wheels. Thanks a lot.
(BTW - Love the XIce2s)
1 - 7 of 7 Posts
