If there was no grommet, I would have also added some silicone sealant.
As far as the fuse, I wish I could provide you with an answer.
Thanks! Eventually I would like to get a grommet or some kind of protection, but I was wondering if the sealant is a good temporary solution, it seems it might works. Lets read other opinions.If there was no grommet, I would have also added some silicone sealant.
If you're using a rubber grommet with just a big flat fill, you would be better off just pushing the wire through so tha the rubber grommet is tight around the cable. That will be more than enough to keep moisture out.I used the exsiting factory gromet, i just cut a hole out for the wire. Im also using 2awg and i wrapped my cable in wire loom to protect it from geting nicked.
