Driver side master window switch, just had same problem, bought a used one for 60 off ebay and now works perfectly
+1: Chaos, but before you pick up a used master switch....Driver side master window switch, just had same problem, bought a used one for 60 off ebay and now works perfectly
Thanks man, if Rick's idea doesn't work that will be my next step.Driver side master window switch, just had same problem, bought a used one for 60 off ebay and now works perfectly
Thanks Rick, you gave me very useful advice as well as a bit of some really interesting facts about the coal and our rain. Ironic that even though regulations were set to "vaguely" protect us we still get the filth in the end.+1: Chaos, but before you pick up a used master switch....
Try removing the master switch (just 5-10 minutes to remove) and clean the electrical parts with some electrical contact cleaner- being careful to not spray your plastic trim as that stuff does clean electrics well but can harm the finish on plastic trim.
A few years ago mine got wet (windows left open) and I cleaned it that way. Been 4 years now and still works perfectly.
Side note: It's not just the rain in Chicago- it is the particles in the air floating over Chicago. You know all that West Virginia and Montana coal that is too dirty to burn on US soil due to regulations? Well, it is mined and sold to China. China burns it for electricity, and that coal dust travels the jet stream down through Canada and travels right over Chicago. Heavy rain can grab some of that coal dust and combine to form a nasty mixture.
Clean that switch first. Remove the panel (three Phillips head screws and use plastic/nylon pry bars to "pop away" the panel clips- don't use a screwdriver as a pry bar) takes 5 minutes.
Be very careful about the door lock cable's little green plastic clip. It is fragile, so gently remove it before you pull the door panel away from the car.
