300,000 mile club
421 Views 10 Replies 9 Participants Last post by  slimm1469
It finally happened. I hit 3000,000 miles on my way in to work
2015 HAH single owner
Original hybrid cell still going strong
See less See more
Reactions: 5
1 - 11 of 11 Posts
Wow.... curious, how is your MPG compare to the first couple years of owning the car? I'm at 170,000 on my 2017 HAH and the last few tanks have been (oddly) nearly as high as when I first got the car (51mpg or so). Typically over the last few years though I've been around 45mpg give or take on a tank of gas except in the winter.
Reactions: 1
Other than oil changes, I'm curious to what maintenance you have done.
Reactions: 1
+1 to wanting to know about maintenance!
Have you needed any major repairs? Out of what you have repaired, what was the priciest?
Reactions: 1
I'm assuming you are directing this towards the OP (and I'd like to know also)... but on my 2017 with 170k miles, I've done the regular maintenance - whatever maintenance minder says I need to do, I get done plus some of the dealer recommended maintenance like transmission fluid replacement. The only repair I've had to do so far was the driver's side window switch would intermittenly not work without being pressed multiple times... it was under warranty at the time, so I've not paid for any repairs so far. 🤞
Love that you're still on original cells and haven't replaced them. Keep us updated on what maintenance you have done. I'm at 139,000 on my 10gen hybrid. So happy to see last gen go well into 300,000 without needing to replace the cells.
I got to 250,000 miles in my 2005 Accord Hybrid before the IMA light came on. Sold it to a backyard hybrid "fixer upper". Hope my new 2023 makes it to 200,000 or so before the batt pack goes out.
It finally happened. I hit 3000,000 miles on my way in to work 2015 HAH single owner Original hybrid cell still going strong View attachment 550149
Feels great to know that my 2018 can last 300k miles. Currently at 86k. Still on original brakes, rotors & spark plugs.
How often do you change the transmission fluid? My dealer says @90k then every 30k after that.
Reactions: 2
^^ when the maintenance minder tells you to. At 90,000 miles you're probably 40,000 miles overdue. That's a guess, since I just got my '15 a few months ago. But on my previous car, an '07 Accord, the maint. minder told me to change the ATF about every 50,000 miles.
165k on an 8th gen. It's only issue was a vtech solenoid badly positioned over the alternator leaking into it. I don't use the MM. I think we need to know our cars' regular maintenance. Agree strongly with mtts60 above -- 30k mile trans fluid changes from new.
Reactions: 1
1 - 11 of 11 Posts
