I want to put Amsoil or Redline in my girlfriends car. it has about 60k on it.
It seems the generally accepted way to change the fluid is the 3x drain/fill cycle.
The "Remaining ATF" column is the volume of oil left in the system after the drain.
The "Z1" column is the number of quarts of stock fluid left after the drain/fill cycle.
The "Amsoil" column is the number of quarts of the Amsoil (or other) ATF after the drain/fill cycle.
I made the assumption that the oils have completely mixed.
*My question is whether or not it is safe to mix synthetic and conventional ATF in this way.*
I ask this because after a drain/fill three times replacing with three quarts Amsoil each time, you are left with 1.31 quarts Z1 in your transmission. I have always heard it is a no-no to mix synthetic and conventional oils.
Please share your insight or experiences.
