1 - 7 of 7 Posts
I had my 60K service done to my '09 Accord EX-L V6 and it seems as though my mileage got worse after they replaced the filters and plugs. Anyone else have this same issue?
2009 accord ex 4 cylinder
What kind of service they did to car ?
Car so nice, bought twice
ECU might need time to adjust to clean air filter and different / better spark.
Thought honda will replace the plugs at 100k?
It's probably all done by MM now, but 100k is the mileage most people will go by with iridium plugs.
I went in for a MM oil change and was told I was due for a 60K service. I am cool with doing whatever the dealership thinks is necessary. They did change the filters and I thought the service guy said they would change the plugs too.
I also thought that the computer might need time to adapt to the cleaner filter. I am not losing a lot of miles. Maybe a mile at most per gallon (if that). I just assumed with a clean filter and whatever else they did, I would get better mileage.
For the record, I have been getting anywhere between 22-25 MPG with 75% highway driving.
thats about normal for the accord v6 with that kind of driving. With the colder weather I average about 24. I put in some gas/water treatment once in a while and some gas/injector cleaner about 2 times a month.
Honda Nation
A plug replacement at 60k is an expensive, unneeded service unless your engine is running bad or you have a check engine light indicating a problem spark plug.
The stock NGKs are the best plugs in the business as far as I am concerned, and to replace them just by what "the dealer says" is just another way for them to rip you off. They're not cheap plugs either, going for around $12.00 each.
It's your money, but you're wasting it.
These plugs are good for 100k always.
1 - 7 of 7 Posts
