thanks for the correction, yes it have a amp but the output of that amp for fronts and rear is full range according to my research and test. In fact the have two small crossovers for the 2-way front set.
I am starting to really like the odea of the MS8, the only disadvantage that I see is that if I dont like the auto tune result I think I will be screwed $$
In Acura's, the POST-amp wires definitely don't sound as clean as the PRE-amp wires. It's easily audible.
The MS-8 is very good at what it does. You can mess up the auto-tune if you're not doing it correctly, but there is TONS of information at DIYMA on problems people are having, tips/tricks to using it, etc. It's very sensitive to input levels (it wants 2v input), it's very sensitive to what SPL you're tuning at for the auto-EQ (can't be too quiet or too loud),etc. It does a great job at putting the stage up top on the dash for most people. My stage was rock solid almost out on the hood...basically just past the windshield. I couldn't locate my sub at all and it sounded like a freaking live concert in that car. Obviously you 'could' do better with manual tuning, but unless you have the equipment to do it, the experience to know what freq. need to be cut, ability to time align well, etc....then the MS-8 will get you 95% of the way there. It's a simple install for the most part, here's what I did:
1. Cut and splice the pre-amp (FL and FR) wires and take them into a line driver (I used the Rockford BLD). If your pre-amp voltage is anything like the 3rd Gen TL, it's very low (around .4v). You'll want 2v for the ms-8. The BLD is cheap, well-built and can do balanced diff if you need it. Great unit!
-- If you'd like to use RCA's to go into the line driver..you can use one of these: (
http://www.sonicelectronix.com/item_17680_Kicker-ZISL-09ZISL.html). I still have mine if you'd like it
2. Purchase nice, shielded RCA's to run from the line driver to the rear of the car (or wherever your amp{s} will be)
3. Take the two RCA ends from that long RCA cable into the MS-8
You're done. The MS-8 can take that full range signal for 2 channels and assign it to all 8 channels. Clean and simple. Obviously you'll need to run other cables/wires for the amp and speakers ...and the MS-8 LCD, but that's it. If you don't like the MS-8, which I don't know why you wouldn't, they are super simple to resell.
