1 - 2 of 2 Posts
hi i bought a mtx audio tn12 and i needed help installing. and i was wondering if i needed a LOC my amp also has a crossover and i have a stock sub. can i just use the signal from the wires going into the sub to the amp and back to the sub. or do i need LOC to use my rear speakers for the signal. thanks:)
what amp are you planning on using? If your amp has speaker level inputs then you can just run the wires to your amp first and then to your sub.
If you don't have speaker level inputs, then you need a LOC so you can convert it RCA level inputs and then run it from your amp to your sub.
Are you planning on using the factory amp? or an aftermarket amp?
1 - 2 of 2 Posts
