Hey guys, new to the site and I'm in need of some quick help if you guys wouldn't mind. I have a 92 accord ex coupe, it has the F22a in it and I've been rebuilding this car part my part for the last year (not like uber fast race car, just replacing all the bad parts) Well heres the story..
I was cruisin around like any normal day and the car just stalled out, this is the first time this has ever happened except for 1 other time when I ran out of gas, I pulled into a gas station and called a buddy, we determined it was the fuel pump, (I always drive on super low gas, at one point the line broke and i was making the pump work 1000 times harder than normal just to keep it running, and c'mon.. its got 223K miles) turned the car "on" and couldn't hear the pump prime, however after I ordered the pump I was told the relay is much more common to go, I figured I'd do the pump anyway, now here are the questions
-Any reason for it to stall like that other than fuel (I have spark)?
-Do I HAVE to drop the tank to replace the pump (some people are telling me I can just replace it through the access hole in the trunk(right behind the back seats)?
-where do I get new tnak straps (advanced said they are discontinued)?
-Some more background on the car -
5 speed, 223,000 miles, driven every day
-Parts already replaced by me (not a shop) in order-
Radiator, Water pump, timing belt & tensioners, both Serp. belts & tensioners, Intake, Full exhaust = header to 2.25' no cat, no resonators, to 2.5 to open muffler (ran out of 2.25'), Oil pan gasket, Cam Seal, upper tube seals, Valve cover gasket, E-brake cable, IAC valve, plugs, wires, dist. cap, rotor.
SORRY FOR WRITING YOU GUYS A BOOK
