A couple of days ago, I found out that my 1994 Honda Accord EX Coupe (83100miles) is leaking oil pretty bad
. Today, a mechanic told me that oil is leaking from "OIL PUMP SEAL", so the timing belt plus many other things need to be changed (oil on the timing belt). The shop gave me a list and an estimate (the air filter was very dirty, so it's included here):
timing belt.............$54.00
balance shaft belt...$54.00
camshaft seal.........$10.00
crankshaft seal.......$10.00
balance shaft seal...$10.00
water pump............$80.00
air filter.................$22.38
the total is $240.38 just for parts :scratch: .
Now, I know that what they charge for parts is way too expensive, so I plan to buy them online and have the shop just do the job.
I have a bunch of specific questions though, and i would really appreciate it if anybody could help me out (I have read a lot of posts in a couple of honda forums on the web about timing belt change, so I know the basics - some of my questions are related to terminology):
0. When searching in online part stores, I could not find any OIL PUMP SEAL - this is the exact word the mechanic used. Is it the same as "balance shaft seal" or any of the other two seals mentioned above?
1. Do you recommend that all the seals be changed even though they don't leak? (I guess the answer is yes!)
2. The mechanic did not say anything, but do I need to change the power steering belt and/or compressor belt as well? is alternator belt and compressor belt the same?
3. which online website do you suggest?
Manchester Honda - http://www.manhonda.com everything is cheap here!
ThePartsBin.com/ProStreetOnline.com - they're exactly the same; the latter is a bit more expensive
T.A.S Auto Parts - http://www.secureleadercom.com/exstore/default.asp?goto=dynfrontpage.asp
Majescic Honda- http://www.hondaautomotiveparts.com
San Leandro Honda - http://www.slhondaparts.com looks like Majestic Honda
I literally could not find some parts I was looking for in Majestic Honda (like balance shaft seal - I don't even know under which section it is listed). That website is very hard to use for someone like me who has limited knowledge of engine - too bad for me; I've read very good things about it. I could not use Majestic Honda, so I used 3 other websites to get a price quote for the OEM parts I need; the results are:
3 seals + 2 belts + waterpump
Manchester Honda : 137.78
ThePartsBin.com : 153.94
TAS Auto Parts : 161.70
3 seals + 2 belts + waterpump + air filter
Manchester Honda : 154.34
ThePartsBin.com : 165.81 or 171.07 (depending on the air filter)
TAS Auto Parts : 180.65
Has anybody here bought parts from Manchester Honda before? Do you know how good they are? Why are their OEM parts so much cheaper than the other stores? Are they reliable?
Oh btw, the price for doing the job, which includes changing the air filter and takes 5.7 hours according to the estimate I got from the shop, is $342.00. $60.00 an hours is not bad, is it?
Thanks a lot
Thanks a lot
