Hi all,
Obviously I am new hear... just found this site. I have a 98 Accord 6 cyl. VTEC with 230K miles. It has been a great car with little to no problems. Recently the transmission has been slipping, RPMs reving some then catching gear. I have tried to stay on the ATF changes but it is old. Local trans shop, very honest and good reputation changed the fluid recently (I took it in for the slipping problem) and they said if the fluid change did not help then I could live with it and let it die peacefully or bring it in for them to rebuild it. Cost would be $1,400-$1,800. I have not made a payment on this car for 6 years and $1800 one time is better than $300/monthly for four or five years on a new car payment... but is it worth it at this age and mileage? I would probably only drive it for a year or so after the repair, but $1800 for a year or so ain't bad... right?
The motor seems sound, but yesterday i noticed a drip of oil. I thought drain plug, but it was running down the back of the motor to the plug. It appeared to be coming from a large bolt in the block immediately above the drain plug on the back side of the engine. Clean oil was forming on that bolt with the engine on. No drips with the engine off. The bold appeared to be holding something to the engine, but I could not get clearance to see what it was. May have even been a line of some kind coming from whatever it was attaching. Any ideas what that is or is it probably coming from the valve cover higher up? Oh yeah, I always used Castrol with no problems, but like an idiot I saved $4 dollars on my last oil change and used Penzoil... now the leak. I am changing the oil Friday morning back to Castrol.
Any thoughts on repairing the tranny and what the leak might be from are appreciated. Dang I hate to punt and get back into car payments.
BFA
BFA
