1 - 2 of 2 Posts
My 99 Honda Accord turn signal works sometimes and the hazards always work. To solve this problem I changed the turn signal switch once, and the turn signal relay 3 times. Any suggestion?
Discussion Starter #2
Problem Resolved by re-inserting fuse
Decided to pull each fuse and test and re-insert in the fuse panel on the driver side by the door hinges; on 4th fuse from the bottom it had no problem, but on re-inserting the fuse the turn signal lights started to work. Be careful in reading fuse locations as I always number items 1 from the top but Honda has 1 on the bottom.
1 - 2 of 2 Posts
