After doing plenty of research on aftermarket audio for the 9th gen accord, I wanted to compile all the important links I found into a single thread. Hope this helps someone.
Door panel removal
Rear tray removal
Wiring Diagram
Sound Deadening Doors
More Sound Deadening of Doors
Rear Deck Rattle Fix
ANC disable
OEM Factory Tweeter mount part #'s
Wiring harness, dash kit, speaker harnesses
RTA info
trevordj's stereo project
LOC install
LCQ1 and LC7i wiring
As for speaker options, many are running the Polk DB6501 or the DXi6501 upfront with no fitment issues after using a 3/4 spacer. Sound deadening on the doors and rear shelf is highly recommended. Below is a general list of what may or may not be needed depending on what your budget and needs are. For better RCA's check out Stinger HPM3 on ebay. For the big 3 upgrade, it may be better to peice your own kit together. I plan to add to this post the factory speaker mounting dimensions and which 6.5's in addition to the polks will fit without having to cut into the door frame.
Polk Audio DB6501 - $127.60
Polk Audio DB651s - $64.99
Audio control LC7i -$140
Speaker Mounting Brackets - $11.99
Speaker Mounting Brackets with Adapters - $20
Very good Amp kit for the money if 0 AWG is needed - $94.95
Speaker Wire - $14.83
RCA cables - $6.60 per pair
Big 3 upgrade kit - $49.99
Fatmat sound deadener - $54.99
Door panel removal
Rear tray removal
Wiring Diagram
ANC disable
RTA info
LOC install
