1 - 4 of 4 Posts
I have an 06 accord ex and every so offer the AC will stop blowing cold and if I turn the AC on and off several times it starts working. It seems to be doing it more and more often. Any ideas?
Try to swap AC relay with Horn (or another similar ) relay in underhood fuse box. That's what happened to me a year ago - relay gone bad, did not send proper signal to the compressor.
If it does not help, you may need to check your refrigerant pressure.
03 EX V6, and 6 others
My 03 did this when the level was low. Then again when the clutch electro magnet was failing (it died completely).
1 - 4 of 4 Posts
