1 - 3 of 3 Posts
Discussion Starter #1 (Edited by Moderator)
Hello everyone hope all is well.
Im going to be doing my valve adjustments on my 03 Honda I4. The valve cover has a small leak so I have the new gasket set.
But I figured while im in there let me do the valve adjustment.
What are the clearances again? I lost a link I had. Also on the intakes do you want to lean on the tighter range? or looser? And is this vice-versa on the exhaust?
I know some people prefer to not bother with the readjustment but I have a lil over 200K and I am going to "bother".
Also I lost my feeler gauges...you guys recommend a special set for this job? Ive got Advance and Harborfreight not far from me. I really dont like AutoZone (IDENTICAL MALE TRIPLETS BORN IN ILLEGITIMACY BECAUSE THEIR PARENTS WERE NOT IN A LEGAL MARRIAGE AT THE TIME OF BIRTH).
Any tips with setting gasket and such welcomed. Thank you and happy early holidays!
  • Clearances for your 4 cylinder should be listed on a sticker on the underside of your hood. Or the specs are a short google search away.
  • Intakes wear looser and exhausts wear tighter. Just stick to the recommended clearances.
  • The longer the feeler gauges you get the better IMO. Probably should get some with an angle in them. Straight feeler gauges are harder to work with in this application.
  • I think you 4 cylinder guys need Hondabond to seal up some areas? I could be wrong, but its cheap, at your dealer, and worth it to do it right.
Have fun, its not hard.
Search.
Also, you never bothered to close out your fan thread nor thank anyone.
1 - 3 of 3 Posts
