1 - 10 of 10 Posts
Old DriveAccord Soul
For the past few months I've been getting an intermittent ABS light. I finally had the codes read; it appears that three of my wheel speed sensors were shot. So I replaced the indicated sensors and I still have the ABS light. I disconnected the battery with no change. Does this have to be reset by the scanner?
Also, anyone know what a fail-safe relay malfunction, 54-01, is?
01 Accord EX V6
Sounds a little funny that 3 of 4 sensors are bad. To me I think you have a computer problem. Never heard of 54-01 code before. If I remember I will look it up when I get to my shop.
06 6MT Sedan
Check this out:
http://www.honda-tech.com/showthread.php?t=1772755
It's for a civic, but it will tell you what the code means. I'm guessing you have a bad ground somewhere.
Discussion Starter #4
06 6MT Sedan
Discussion Starter #6
Excellent, thank you! I am hoping that it is not the modulator unit, that is $500 plus. Ouch.
06 6MT Sedan
No worries. Hope it helps and hope you can get it fixed on the cheap!
If you clear the codes, you must perform the TCS/VSA neutral position memorization or you'll get a constant code 84 with the lights on.
Discussion Starter #9
I have a 2.4 LX, so I do not have TCS/VSA. Do I still need to do anything? I checked all the relays and fuses. All are good. I also checked the grounds, they look good too. :dunno:
No you shouldn't. I should have read your signature.....
1 - 10 of 10 Posts
