Hi, I replaced the left front sensor about a month ago after the light came on, Everything was fine for about a month now I am getting the same code for the same side, I replaced it with a Factory Sensor. Any Ideas? the ABS Sensor wheel looked fine. Thanks
if it the tone wheel is ok(no low spots, material on it, air gap is good) and
the sensor is confirmed good(measure resistance of the right front sensor and compare it to the new sensor, should be reasonably close) and
the wiring to the control unit measure proper resistance(typically no more than .1 ohm) and do not have continuity to ground
then replace the control unit (behind driver side kick panel 4cyl or pass side kick panel v6) although exact year, body style and engine would help me give you exact information if you need it.
