1 - 5 of 5 Posts
This morning I got in my car and started her up, and all 3 of my breaking system lights stayed on. the ABS, TCS, and the /!\ lights. I am baffled about this. I had no warning that anything was going wrong. So now I have no ABS system or TCS system. What could be wrong. I can not find this specific problem. The car is a 2003 Accord EX V6 with 120,700 miles on it.
Welcome to DA!
Braking system, not Breaking system. ;-)
It could be a wheel speed sensor, did you turn off the engine and try again? You can also disconnect the battery for and reconnect to see if that resets the system.
Also, have a read on the this thread, you can find it by searching "ABS TCS" from the Search button near top of the page and select 7th Gen forum . TSC and Brake Light On
Otherwise you will have to get the diagnostic code(s) read by a shop with the right equipment, then determine the course of diagnostic action.
Lastly, I seem to recall a weak(er) battery could cause this, but don't hold me to that one without getting the battery checked out properly through load-testing.
I <3 My Honda
You can also double check and recalibrate / set your brake light switch...ensure that the switch is being fully depressed with the brake pedal resting and fully disengaged when you apply pressure to the brakes.
Doing trumps "I've read".
1 - 5 of 5 Posts
