It took about 20 min per car. I got the power using spade connectors and a short piece of wire, then made a jumper that taps off the back of the cigarette lighter, so I didn't have to splice into the factory wiring. Then I used some Honda EPT sealer tape to cover everything.The 3 coil charger allows it to sit anywhere in the cubby and work. The charger comes with the red/blue LED lead. When you have the center console out just pop the top cover off the cubby and wedge the LED board in the top. The cover will snap back on and hold it in place. So it can all be removed if you want, without any permanent modification to the car.
Video of it in action (22mb) https://app.box.com/s/lti8mebmvge7r6gkdobr
Charger http://goo.gl/j0ExJ9
Power supply http://goo.gl/W2JtrQ
