hi all, got a po135 code front A/F o2 sensor heater circuit failure. 2007 accord auto 4 cylinder 40,000 miles. Purchased a Honda replacement sensor. I have not been under the car yet. I hope you will give me the benefit of your experience about the following questions.
1. is there clearance to use a 7/8" or 22mm wrench or O2 socket to remove the O2 sensor, or must you use a Oxygen sensor removal crowfoot locking adapter
2. does the clip that holds the O2 cable need to be replaced and/or is it difficult to open and close, and what tools should I have for the clip.
Thank you very much for your help and advice.
honjac
honjac
