1 - 1 of 1 Posts
AEM PLUG & PLAY ENGINE MANAGEMENT SYSTEM – SERIES 2
AEM’s Series 2 Programmable Engine Management System is more powerful than its predecessor. In addition to more robust hardware, there are several improvements over the original EMS, noted in the chart below. Like its predecessor, AEM's Series 2 Plug & Play EMS plugs directly into a vehicle's factory ECU harness and requires no additional wiring or hardware. Windows™ compatible software (XP, Vista, Windows7) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. Our new AEMTUNER software is infinitely adjustable software and allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately delivers proper amounts of fuel and correct ignition timing for any boost level or operating condition.
• Plugs directly into the factory harness. No rewiring necessary.
• Uses all the factory sensors.
• Includes start up calibrations.
• System is fully enabled and unlocked - Never pay for upgrades!
• Context sensitive help eases tuning process.
• Maps can be password protected by the tuner to prevent unauthorized usage or sharing.
• Runs on Windows-compatible software.
• Up to 12 peak and hold injector drivers.
• Up to 8 direct-fire coil outputs.
• Up to 16 general-purpose outputs.
• Up to 8 definable switch inputs.
• Up to 4 EGT inputs with fuel trim.
• 1MB of internal data logging.
• Electronic boost control.
• Full idle control.
• Programmable traction control.
• Software definable knock control.
• Two step launch control.
• User configurable soft-cut rev limiters.
• Wet or dry nitrous control.
• Tune using new USB communication port or serial port.
• Works with all AEM gauges.
AEMTUNER SOFTWARE FEATURES
• Support Pane gives tuners context sensitive help and uses tuners’ actual calibrations to describe each function.
• Internal conflict detection notifies tuner if obvious errors exist in assignment of inputs/outputs.
• Compare Calibrations allows tuners to graphically compare tables and maps for easy analysis.
• Workspaces are easily customizable and configurable.
• Colored tables and maps.
• Data analysis using AEMdata software.
APPLICATIONS:
1990-1990 - Accord EX - 2.2L 2156cc L4 F22A1 - M/T
1990-1990 - Accord EX - 2.2L 2156cc L4 F22A4 - M/T
1990-1990 - Accord LX - 2.2L 2156cc L4 F22A1 - M/T
1990-1993 - Accord DX - 2.2L 2156cc L4 F22A1 - M/T
1991-1991 - Accord EX - 2.2L 2156cc L4 F22A1 - M/T
1991-1991 - Accord EX - 2.2L 2156cc L4 F22A4 - M/T
1991-1991 - Accord EX - 2.2L 2156cc L4 F22A6 - M/T
1991-1991 - Accord SE - 2.2L 2156cc L4 F22A6 - M/T
1991-1993 - Accord LX - 2.2L 2156cc L4 F22A1 - M/T
1992-1992 - Accord EX - 2.2L 2156cc L4 F22A6 - M/T
1993-1993 - Accord EX - 2.2L 2156cc L4 F22A6 - M/T
1994-1994 - Accord LX - 2.2L 2156cc L4 F22B2 - M/T
1994-1995 - Accord DX - 2.2L 2156cc L4 F22B2 - M/T
1994-1995 - Accord EX - 2.2L 2156cc L4 F22B1 - M/T
1995-1995 - Accord LX - 2.2L 2156cc L4 F22B2 - M/T
1996-1996 - Accord DX - 2.2L 2156cc L4 F22B2 - M/T
1996-1997 - Accord EX - 2.2L 2156cc L4 F22B1 - M/T
1996-1997 - Accord LX - 2.2L 2156cc L4 F22B2 - M/T
1997-1997 - Accord DX - 2.2L 2156cc L4 F22B2 - M/T
1998-2002 - Accord DX - 2.3L 2254cc L4 F23A5 - M/T
1998-2002 - Accord EX - 2.3L 2254cc L4 F23A1 - M/T
1998-2002 - Accord EX - 2.3L 2254cc L4 F23A4 - M/T
1998-2002 - Accord LX - 2.3L 2254cc L4 F23A1 - M/T
1999-2002 - Accord LX - 2.3L 2254cc L4 F23A4 - M/T
1999-2002 - Accord V6 Swap - J30A1 Swap - M/T
GO TO NOPI AEM Electronics & Performance Catalog for model specific details
Contact the salesmen below or PM me for "DRIVE ACCORD" deal with FREE FREIGHT
1 - 1 of 1 Posts
