1 - 3 of 3 Posts
I have a 2004 4cyl Accord with a problem I never faced before. Just recently the cooling outputs on the passenger side deliver cold air when the air conditioning is turned on while the driver's side has only unconditioned air being delivered. This occurs in all air condition modes of operation. Any assistance offered will be greatly appreciated.
Elvira
sounds like the rod that controls the damper door for your side of the duct either popped off (hope,hope,hope) or it broke and the air is not getting to that side of the duct.
You may want to look under the dash on the driver side at the ducting to determine if you can see what is loose or missing or out of place. All the linkage I believe is visible and should be obvious.
Miker
1 - 3 of 3 Posts
