1 - 5 of 5 Posts
The other day i noticed my oil light came on and after pulling off the road and doing a quick inspection I noticed all the oil had poured out. I have narrowed it down to either the crank shaft seal or balance shaft seal. I wont have time to work on it until after the new year, but I want to buy what I need now.
I will be replacing the timing belt and water pump while I am at it. Besides the two seals I think it might be, is there anywhere else under the timing belt covers that oil could be coming from?
Thanks
Im guessing this is a 4 cyl, so technically the camshaft seal is also behind the cover, but the other two seals would be the primary leak suspects.
I presume the engine is still ok following the loss of oil. It would be unfortunate to replace all the parts and then discover the rods are knocking.
Yes it is a 4 cyl.
I think the engine is ok. i\I probably drove 2 miles with the oil light on and I didn't hear any noises. It would definitely be a shame to go though all his work just to find out the engine is messed up. Do you think it would be a good idea to keep pouring oil in the engine while its running to see if there are any noises?
If the engine sounded normal when you last shut it off, its probably ok. I would certainly fill it with oil before restarting it again. Was the oil level below the dipstick or did you just get an oil pressure light with the level ok?
I was not to far from my house when all the oil poured out. I filled it right up before I left the gas station and barley got a reading on the dip stick. The oil was literally pouring out while I was pouring it in the engine. I was about 2 mins from my house when the oil light came back on. I parked the car in my underground spot and when I came back out to look at it, all the oil was on the ground again.
The engine sounded normal the whole time.
1 - 5 of 5 Posts
