1 - 7 of 7 Posts
Hey guys,
My alternator mounting bracket snapped in half the other day (V6). I replaced it, but I'm thinking it broke because around 1,000 miles earlier I tightened up the lower alternator bolt to reduce belt squeal. I'm assuming I tightened it up beyond the 33 lbs of torque recommended by Honda which caused excessive vibration to the alternator bracket. So I'm trying to do it "correct" this time with a torque wrench but there's no way to fit one in there! The only tool I can fit down there is an off end box wrench. How can I get the torque correct on this bolt, anyone?
Kaua‘i North Shore Boi.Aloha❤️🤙💪😊
What I've done, and it's hard, but I Now RARELY break the heads off bolts anymore, is, I get a bolt, same size, and practice a bunch of times.. tTryry to get a feel for it. Then I go for it. Works in a pinch!
Aloha🤙🤙🤙🤙
Been there done that, it is not because you tighten the bottom bolt to tight. Did you break the bottom bolt? My guess is you put the Alternator in a bind and broke the top bracket because the alternator was not lined up properly.
Are you referring to #1 on this image?
Sent from my Pixel 3 XL using Tapatalk
Discussion Starter #5
I replaced part #1 but the bolt I'm referring to is #16. It is on the bottom of the alternator. It has a long thread so its easy to keep on tightening it.
No I didn't break it.
The belt began to squeal some so I tried tightening the bolt. It helped the noise a bit, but within 1,000 miles or less the bracket snapped in half. Driving down the road the electronics went wonky so I pull over to check and the alternator is hanging by one bolt (the bottom one). Somehow the belt was able to intermittently drive the alternator even though a toddler could have pulled it off it was so loose.
My thought process is that an overtightened bolt would reduce the belt deflection and put a strong sheering force on the bracket. Regardless I'd just like to get it torqued to spec just wondering if there's a special tool to do so....
You will need an extension and with the extension you will have to calculate what Tourqe to set with that extension.
Discussion Starter #7
Thanks for the help anyway guys I decided to just give up. I bought a set of wobble extenders but there's just no way I could find to get the bolt to turn without the socket slipping off. No room at all for a deeper socket and while trying to turn the nut was actually scraping up on the tensioner -- decided I didn't want to risk gouging that up and causing premature belt wear. With a significant amount of effort I managed to get a crow foot wrench on it but could only do a fifth of a turn at best.
1 - 7 of 7 Posts
