1 - 5 of 5 Posts
Hello
I am trying to install ambient light, but wondering that disconnecting battery is necessary? it's not that hard to do it, but you know.
any body experience w/o disconnecting battery?
thanks
The taste of Vtec!
No need to disconnect battery
Just pull out the appropriate fuse. Whenever you're doing anything electrical, it's always a good idea to cut power to whatever you're working on, just to be sure. :yes:
The taste of Vtec!
I changed mine like 2 months ago everything flow but if u want safety then pull it off its not much work just annoying to putting on and test and go back and forth lol
Doc Mojo
12 volt source with very low amp can't kill you. but do remember to turn off the light switch when you're plugging in the ballast. 1000 volts CAN kill you if your bulb does something weird. If you bought your kit from China, be careful. Taiwan, korea, japan... those are safer.
1 - 5 of 5 Posts
