1 - 6 of 6 Posts
Hey all! I was wondering if anyone knows if I can install an amp and sub on my factory nav unit. I hve a 2006 coupe. Does the nav unit have RCA outputs?
06 6MT Sedan
No. The Nav unit does not have RCA outs. You need a Line Out Converter. Something like a JL Cleansweep or an MTX REQ5. This will convert the speaker wires to RCA outs. I can sell you a JL Cleansweep for cheap ... :)
HAHA :thmsup: thanks I appreciate the offer! How hard is that to install? And how well does that work or any cons to using that?
06 6MT Sedan
Or you can find an amp that accepts speaker-level inputs. A low-level line out converter is easier.
I have found that amps that accept speaker level inputs don't do as good a job as a quality LOC. My BassLink accepts speaker level, but I never bothered testing because the reviews stated the sound was a lot better with RCA inputs.
06 6MT Sedan
You will need a wiring harness to tap into the factory wiring. The harness makes it much easier. I have my LOC in the trunk, along with my amp, cap and sub. It's not a really hard install, but I have been working on my own stereo systems since the early 1990's. If you have never done this before, it is doable, just do a lot of research and do it right ...
1 - 6 of 6 Posts
