1 - 6 of 6 Posts
Hi all,
Newbie to the audio upgrade world.
I've purchased:
- Single 10" Rockford Fosgate R2D4 and sealed box
- JLA JX250/1 mono amp
- JLA RBC-1 Remote Bass Control
- Amp Wiring kit
I've read all the sub/amp wiring/installation threads on the forum but I'm still needing help in one area.
Specifically, since my amp has speaker level inputs, do I still need to buy a LOC? I'm under the impression that I shouldn't but it seems like everyone uses them regardless. I'd rather not use unnecessary parts for obvious reasons.
You might hear engine noise through the speaker level inputs. A LOC eliminates that.
I never knew this...not saying you are wrong, but can you explain how? I have always used a LOC, but only because my amp never came with a speaker level input.
I wired up a 4 channel amp with speaker level inputs. I had engine noise, even when the radio was off. I was told that the low level signal from the factory head unit was the cause. The LOC cleaned up the signal and got rid of the engine noise.
1 - 6 of 6 Posts
