Hi, just want to share a newly uploaded video on YouTube describing how Honda’s e-CVT ‘transmission’ works.
I know, I know, it is not a traditional transmission with varied gear ratios; from a broader perspective it serves the same purpose of diverting engine power to the front axle just as a traditional transmission does.
Some interesting points I picked from this video:
1. An additional 2.455 reduction gear is there from motor to front axle, making the motor to final gear ratio 8.398. I wasn’t aware of this reduction gear before.
This puts 232 lb ft of motor torque amplified to 1948 lb ft if I do the math right.
2. A permanently applied clutch is there on the flywheel for safety breakaway. This is something good to learn.
3. This e-CVT ‘transmission’ needs ATF similarly to a traditional transmission. The ATF serves the purposes of cooling, engaging clutch, and lubricating gears.
It seems no much fluid will be left inside during ATF change since the inside structure is so much simpler than stepped ATs.
