1 - 5 of 5 Posts
I've been having problems with my driver's power window (Accord Coupe). When I roll the window up, it goes all the way up. However, it then will intermittently sound like it's trying to go up, and it will make a small surge upward then stop (because it has nowhere to go). After it does this, I am not able to engage the switch to make it go down. After a few clicks, or wait a few seconds, it seems to reset and then I can bring the window down.
Has anybody ever heard of this problem or know of a fix??
A few years ago I opened the door and replaced a small component inside the regulator motor (can't remember what it was).
yeah can you post the steps; my passenger side window been doing this since I purchased the vehicle, I always thought it was the master switch that was no good because it only happens when i use the Drivers switch i can go up/down all day using the pass. side switch with no problem.
1 - 5 of 5 Posts
