I noticed the wireless dongle has an HDMI plug and not the USB found in our Hondas.Has anyone tried this product? Umhug device
2018 Honda Accord Touring 1.5 Lhow did you download it? I went to 192.168.50.2 like they told me and it says no updates
PLEASE let us know how it goes when you get it. I went through the whole process of ordering it from China and then having to return it. I'd love to know that they've made it work for the 2019 and up Accords.They’ve now said it’s supported for Accords. Mine is on a slow boat from China so we’ll see when I get it.
I’d like to know as well - can/should I reconnect my phone to the head unit after installing the dongle? I think it’s required for HondaLink.Carplay2air/Carlinkit latest firmware v 28.10.2020 supports all Honda vehicles which includes 10th generation Honda Accords (2018 and Newer). Carplay2air sent an email update to all those who registered in their website for Honda Accord Support.
One 2019 Honda Accord user tested and confirmed in another forum.
I will update my Carlinkit to latest firmware and confirm soon.
With the unit plugged in, you should be able to see a wifi network that could be something like auto link or Volkswagen or something else. The password for whatever this network ends up being is 12345678, connect to it. Go to 192.168.50.2 and check what version of software it's on. If it's 8.04 or older then you need to get it to update. I would recommend, for this update, that you have the unit plugged into an ac adapter at home in case it loses power in the car for some reason. After this update, when you plug it into the car again, CarPlay should work wirelessly.I got my cplay2air today, but when I plug it in, nothing happens except the radio asks if I want to enable CarPlay for the device. Nothing from the instructions is happening. I cannot connect to it via Bluetooth or WiFi. I am completely disconnected from all WiFi and have deleted all of the Bluetooth settings for my car on the phone, and have deleted everything from my car Bluetooth about my phone. Any help would be appreciated.
Thanks for the info, cplay2air worked like a charm! Key is changing or renaming the file to U2W_Update. I have a 2020 Hybrid Touring FYI.2018 Honda Accord Touring 1.5 L
Format 8GB pendrive using FAF32 file system with default file size.
Download and store the 28.10.2020 firmware from https://github.com/ludwig-v/wireless-carplay-dongle-reverse-engineering/tree/master/Firmware in the pendrive. (Make sure to rename the file to U2W_Update)
Connect the Carlinkit/Carplay2air to a USB Wall power outlet
Wait for the solid Red light.
Insert the pendrive into the Carlinkit/Carplay2air and wait atlest 4 minutes while the device being updated (You will see alternative red light and green light on the device and finally solid red)
Delete all Wi-Fi and Bluetooth from Phone and Car (then make sure both Bluetooth and Wi-Fi are tuned on in the phone)
Insert the Carlinkit/Carplay2air once the head unit is fully booted.
Select the Phone from the Carlinkit/Carplay2air screen you see.
Wait for the setup to complete
I used the usb method above which worked - for like 20 seconds. I checked for an update (I guess I was stupid to think there would be another update), which it said there was. I clicked update. It said the update was successful - then the lights blinked blue really fast and went out. They have not come back on - restarted the car, unplugged and re-plugged in the dongle. Nothing.With the unit plugged in, you should be able to see a wifi network that could be something like auto link or Volkswagen or something else. The password for whatever this network ends up being is 12345678, connect to it. Go to 192.168.50.2 and check what version of software it's on. If it's 8.04 or older then you need to get it to update. I would recommend, for this update, that you have the unit plugged into an ac adapter at home in case it loses power in the car for some reason. After this update, when you plug it into the car again, CarPlay should work wirelessly.
Those are the steps I took except I have a carlinkit I got from amazon which is supposed to be mostly identical.
EDIT: The USB method to update may also work. The most important thing from my post though is that the wifi password is 12345678
I had a similar experience with the first Carlinkit I purchased. I exchanged it with Amazon and got lucky this time. Unfortunately these units seem finicky. It’s very possible that your unit is bricked and you need to have the company swap it out for you :/I used the usb method above which worked - for like 20 seconds. I checked for an update (I guess I was stupid to think there would be another update), which it said there was. I clicked update. It said the update was successful - then the lights blinked blue really fast and went out. They have not come back on - restarted the car, unplugged and re-plugged in the dongle. Nothing.
I plugged it into a USB power adapter, and there was a faint blue light but nothing happened. I unplugged it, then replugged it back in, and no lights. So far this has been a VERY frustrating experience. I guess I should not have trusted the built in software updater. Any suggestions on what to do now? I am trying to get the USB firmware update to work again, but I cannot get the red light to come on when plugged into a USB power adapter. Should I assume it is bricked now?![]()
That's what I am afraid of - I ordered mine directly from cplay2air.com. So most likely it is going to be a pain to get a replacement - which is why I am hoping I can get it working again.... If anyone has any suggestions???I had a similar experience with the first Carlinkit I purchased. I exchanged it with Amazon and got lucky this time. Unfortunately these units seem finicky. It’s very possible that your unit is bricked and you need to have the company swap it out for you :/
Tried the carplay2air will driving to a from work and I had multiple freezes and one time it wouldn't connect at all. I've emailed support but I'm guessing they won't have a fix. I just find it odd how they specifically said it didn't support Accords at first, then they said it did and it clearly doesn't support the 9th gen.I got my cplay2air today as well. At first it just kept trying to connect and failing, but then I did the update and it connected after that. I wasn't going anywhere, but I purposely tried to stress test by jumping around screens and scrolling and in a couple minutes of testing, I had the screen freezeI was able to recover by going home on the head unit and carplay launched right up again and worked again but that's not good. So as mentioned above and what I suspected, I guess all these units are basically the same. The instructions are the same so I suspect this is going to freeze like the Carlinkit I got on Amazon. Again, I have a 2017 Accord, so maybe it will be better in the 10th gens.
Sorry for your troubles Macmuchmore. I know how frustrating that can be.
I would recommend purchasing the Carlinkit version of the cplay2air from amazon vs purchasing the cplay2air from China like I did. With amazon, returns are easy. They are the same hardware and use the same firmware - not sure why 2 companies are selling the exact same product.... Anyways, I am going to have to return mine to China and it is going to be a pain.PLEASE let us know how it goes when you get it. I went through the whole process of ordering it from China and then having to return it. I'd love to know that they've made it work for the 2019 and up Accords.
What is the name of the file you are trying to install? My update somehow changed the name from U2W_Update.img to U2W_Update.img.28. all I did was remove the .28 on the filename and it updated itself within 3 minutesJust received my dongle from Cplay2air and I followed the instructions of updating the firmware...placed the file on a USB and plugged it into the dongle, then into a USB wall adapter...no light is blinking or solid. Does this mean I have a faulty one based on everyone's experience so far?
Same thing, U2W_Update.imgWhat is the name of the file you are trying to install? My update somehow changed the name from U2W_Update.img to U2W_Update.img.28. all I did was remove the .28 on the filename and it updated itself within 3 minutes
Have you been able to return yours? If so, how did you do it?So it looks like my cplay2air is bricked. I will be returning it.
