1 - 3 of 3 Posts
Hey everyone,
I was just curious if anyone had put a 20mm wheel spacer on rear with the 2019 touring rims? From what I can tell the pockets(?) on the rims are too small and won’t clear the bolt which would still stick out of the spacer.
If so 2 questions:
(1) Would a 25mm spacer cover the bolt completely? is that too wide (the 2019 rims are 19x8.5 +50) for a 19x8.5 +25 offset in the rear essentially.
(2) From what I’ve read everyone recommends against a 10mm spacer without replacing the bolts - or anyone running them fine.
Thanks.
518897
I have a 2016 EX-L 6MT and I had a 15mm spacer in the rear before with the stock rims. I believe the stockies have the same width and offset. I was lowered on H&R springs and never had an issue. I think the 20mm would have cleared but I was satisfied with the flushness the 15mm provided.
Thanks gdm, I think the 2016 would have been 18x8 +55 vs the 19x8.5 +50, could be wrong though.
Has anyone had a set up of 8.5 wide with a +25 offset on the rear? I'm thinking it would stick out, but the rear does have alot of space.
1 - 3 of 3 Posts
