Hi all.
For the back-story see below.
I thought I'd share my latest project. I also have some questions about Honda's new ATF, DW1 (Z1) Vs Red Line D6 (D4):
According to Red Line's webpage the new Honda ATF DW1 is compatible with RL D6. And Z1 is D4, what meany of us use (I was using AMSoil). Are we now gonna use D6? For now I plan to used DW1...
I plan to add a transmission cooler, in-line with my radiator cooler (ahead of):
Transmission ATF Output cooler line, will go to a Magnefine filter, then a 4452 Tru-cooler, and then the Radiator OEM cooler, and then back to the Transmission ATF input.
The External cooler:
http://www.ebay.com/itm/370893144123?
This is contrariety to this forums standard, putting the external cooler last. Here is why I am doing what I am doing:
ATF has two boundaries to keep it between, not lower than 100F and not higher than 220F.
The bottom of a well functioning radiator is 30-40 degrees lower that what went in. In our case this is 207F, for easy math that's 210F. 210F - 30F is 180F, this is worst (normal) case. Normally its (182F) 180F - 30F = 150F.
By pre-cooling the ATF, the hottest the ATF will be going back to the transmission is 150-180F. And the ATF wont be adding heat to the radiator, letting it work better, and run cooler. When its cold out, the ATF wont be over cooled, and will get slightly wormed up.
Is something I've missed?
aranoid:
As some of you know, I just had my transmission fully overhauled. The transmission shop prefers disconnecting the radiator cooler completely, and just using an external cooler. This from my research, seem to be a bad idea. I got the OK to add the cooler my self, and they want me to keep the DW1 till my first ATF change, at 30K, that I'll do at 15K. Then 30K there after.
I now live where I climb a hill every day to get home. I'm running at 200-207F, by the time I get home. I expect that this is mostly heat from the slow winding road and ~1000Ft climb. Of witch is mostly the ATF heat transfer via the radiator cooler, as I currently dont have an external cooler...
