1 - 20 of 21 Posts
Hi all,
So I took my '06 Accord to rust-proof at Krown (a Canadian chain). Afterwards I found out what a terrible job they did with the drilling - one of the plugs doesn't even fit flat on the surface. I had to spray extra rust proofing around the plug so the water wouldn't seep through the hole every time I wash my car.
Does anyone know how I can fix this problem?
Thanks!
Eric
7th Gear
Take it back and make them do it right.
I live in Toronto with pretty bad winter and roads are salted 5 months of the year. So rust proofing is necessity.
Your first mistake was getting rust proofing.
Disagree, my 10 year old 1996 Integra had no rust when I sold it in the typically susceptible areas like rear wheel arch, bottom of door corners, tail gate opening etc. as compared to many similar model year Integra, I have to attribute this to me spraying the thin liquid type rustproofing such as Krown or Rust-Check every fall.
OP, pop the plastic plug off to see if there is anything obvious, it maybe a plug that was installed crooked, maybe caught an edge of the plug etc.
Well what do I know:lmao:
I still don't even understand what's getting rust-proofed? Are there holes in the body where water can get into things like door panels?
Discussion Starter · #12 ·
@thisaznboi88
about CAN$130
@ikethegreat
to get to the inside of the panels
@jdmorg
exactly - because salt water can get in during winter
@thisaznboi88
about CAN$130
@ikethegreat
@jdmorg
Soooo through these little holes and through application of the product, the whole inner door panel is completely rust proof?
Maybe this whole conversation is going over my head, but this all sounds like snake oil to me. I don't think I've ever seen a car made in this decade that had those kinds of rust issues.
As for road salt and grime, sealant, wax and a good spray down of the undercarriage in the spring. Some of the drive-through tunnels around me even have the undercarriage spray option. I spring for that and then just scoot out before the soap starts falling (those soaps can be harsh for wax)
Moderator
In the US a thick goop is used and should be avoided at all costs. Up North it's thin like WD-40 and is widely used since it works very well. Not sure why the good stuff hasn't migrated South but probably has something to do with patents I'm guessing.
I just don't understand it as I've never heard of it before. What about things like the window and door mechanisms? The speakers? The wiring? Is everything coated?
Discussion Starter · #20 ·
They stick a long tube inside the panel through the hole and spray. The windows usually don't get coated but not sure about other parts.
1 - 20 of 21 Posts
