1 - 6 of 6 Posts
Were did everyone install the bass knob after they upgraded there sound system? Not sure were to put it how often do people mess with it after installation. If you have one can you post a picture of it?
In my past car, I used an empty switch panel to the left of the steering wheel. Blends in well with other switches and no one but the driver will be able to reach it.
Yeap! depends on your model but there is an empty switch by the Honda Sensing on/off button to the left of the steering wheel. I just finished placing my AudioControl knob there. I had to dismantle the knob housing and do some cutting on the dummy button. It was about 20-30 minutes all you need is a drill and blade/Exacto knife to modify. got the led in there as well. All panels and the button are pressure clips.
521660
I put mine in the center cubby. so its out of sight out of mind. I dont play with it as, even around the lowest setting its such and improvement over the stock sound. Just a touch of base just makes it sound so much better, so i leave it alone.
youtube.com/justahondaaccord
521954
1 - 6 of 6 Posts
