Hello
211K miles on my Accord, owned since 125K miles with unknown prior service history.
Never had a battery charging issue (just old crap battery before). I upsized the battery to the bigger 24F V6 type two years ago as recommended here and it's been flawless in super cold Vermont weather after sitting a week even.
Drove hour to work, at end approaching parking low speed, battery light came on 3x and went out. All happened in a matter of 1-2 minutes at most.
After sitting 6 hours, car started up easily -full battery power easy to observe.
Drove back home hour (48 miles mostly highway), battery read 12.7 VDC engine off.
Next day started car - idling 14.7 DVC reading. Nice and strong.
So... do I worry? Alternator going? It does have some slight PS fluid leaks around / on it.
I have a 1995 Kawasaki ZX600E motorcycle that had a dying regulator / rectifier that was 100% intermittent as the diodes in the stock OEM under capacity Regulator / Rectifier were dying. R/R was super hot to touch as it stopped charging the battery and stranded me 6 times over months. At idle back home (cold engine / engine on) testing it always metered a cheery 14.7 VDC. It had to get hot out on the road driving 20+ miles or more and then finally caught it below 12VDC as I had wired up a voltmeter to battery and had it in view in my tank bag on a ride.... replacing the R/R and upgrading the gauge of wiring from the Stator completely solved the getting stranded problem!
So I know in a different system, different case: Moto with Stator and Regulator / Rectifier separate combo charging system vs Auto Alternator all in one heavier unit - maybe these have nothing in common (?)
QUESTION: can a failing / dying alternator output 14+ VDC correctly and then intermittently charge / no charge a battery in a car?
(connections at battery are tight and look good. little to no corrosion at posts).
