This concerns a new 2019 Accord Hybrid (~7000 miles). Under normal operation under 75 mph, the battery cycles between 20-50% charge on the highway, with the engine coming on intermittently to charge the battery.
However after driving for more than 60-90 minutes, the engine no longer cycles and stays on. During this time, the battery will charge but not discharge, causing the charge level to climb to 100%. Trying to force EV mode results in a message "Battery Temperature at Limit", despite the outdoor temperature being anywhere from 20-70 deg F and cabin temperature being 66-70 deg F. This condition resets after about 10-15 minutes of driving, with the engine cycling on and off again. After a further 10-15 minutes, the engine will be stuck on again. This cycle results in a loss of about 5 MPG over the standard behavior.
My read on this is that the battery is used for both regenerative braking as well as adding or removing the torque load from the engine to keep it at the optimal brake specific fuel consumption for the given road speed (and RPM at lockup). When the battery goes into an overheat condition (i.e. battery temperature at limit) the ECU no longer uses the torque loading/unloading trick, resulting in the engine operating at suboptimal BSFC and causing the MPG loss. The battery is only used for regenerative braking, which means that the charge rises until the battery eventually cools and the condition resets.
My question is, is this something that any of you have noted? Does your MPG drop after > 1 hour of driving? Is there something wrong with my battery/cooling system? I'm quite skeptical that Honda would design the system to not be able to cool the battery down at steady state highway driving.
