1 - 9 of 9 Posts
I am going to build a rack out of MDF to mount my 2 amps, a LC7i, and the component crossovers inside of my trunk. It will be a vertical rack with the equipment facing forward. What is the best way to secure the rack in place? I am not that worried about removing it later, rather I am worried about vibration from the sub, quick stops, etc causing it to come loose and fall. Thanks for the advice. Pictures are even better...
Mod it or don't drive it
That forum has LOTS of great info that I will certainly use for the doors, rear shelf, wiring, etc. It does not have what I was looking for with the amp rack. His rack was smaller and mounted horizontally below the shelf. I want to make a vertical rack that fits under the shelf and is accessible by putting down the rear seats. Thanks though.
buy or fab up some kind of L brackets.. attach them underneath the rear deck and then to your board ?
I figured that would be a good idea. I do want it to look good as well, so I don't want to just bend a little bracket to fit. Has anyone done this and will post a photo to share?
You could put the amps on raised plexiglass like I did on one of my setups. How much trunk space are you trying to retain lol?
Discussion Starter · #7 ·
That looks sick as shit!!!, but I actually want a usable trunk. I have a 15" Alpine Type S which takes up quite a bit of space. The added amp rack needs to be vertical and fit behind the sub, under the deck, since this is my only vehicle other than a motorcycle and I cannot give up the whole trunk.
I used l brackets and they work for now. I will probably fab something out of steel and paint it this summer
1 - 9 of 9 Posts
