2018 Honda Accord 1.5 turbo:
As of now 77,000 miles (almost 78,000) I'm the second owner.
The first owner put 39,000 miles on it. Every time the car needed work, while in my possession, it went to a Honda shop.
I'm not sure about the previous owner, but I'm sure I can find that information.
Just recently, back in July it started having some issues.
First, it started with a hard start and engine would shake for about 3 seconds. Then it settles and seems to be okay, but I would hear liquid pouring somewhere. (This can all be heard and felt within the car) at this point there weren't any check engine lights on, oil level and color looked okay, coolant level was normal and it drove fine.
For a little bit. About 2 weeks after this started the second issue popped up. At about 45-50 miles per hour the car won't accelerate, the check engine light comes on and it starts giving several prompts.
1. Tire Pressure Monitor System Problem 2. Emissions System Problem avoid heavy acceleration and high speeds
3. Brake System Proble
4. Vehicle Stability Assist System Problem 5. Adaptive Cruise Control System Problem
6. Lane Keeping Assist System Problem
7. Collision Mitigation Breaking System Problem
8. Road Departure Mitigation System Problem
All ending with see your dealer.
Scanned it and the code was P0303. Oh, simple fix, replace the spark plugs. That's what I hoped, knowing it could be more. Also, this had me wondering why spark plugs on a Honda would be going bad at 77,000 miles. It worked, for a day. So then the ignition coils were replaced. And that fixed it. So I thought, kinda. I was still thinking in the back of my head, why?
Well now, I have my answer. It had continued to have the rough started and the fluid rushing in sound for the last few months. I drove it as little as I possibly could as I knew there was a deeper issue. I just wasn't sure what and didn't have the money to go hunting/fix it.
Problem number 3, it comes up with a warning that the engine is too hot to drive. Yes, the temperature gage was all the way up to H. Then before the car could be pulled over to a safe location it went back down and the warning message went away. I was less than 5 miles from home and drove it there to sit until I could get it to the shop after the weekend.
The shop came back and told me that I had hydrocarbons in the coolant system! NO! In a Honda? With only 78,000 miles? Very odd. Then he proceeded to tell me that he is just as caught off as I am, so he had dome some googling and found that the 1.5 turbo is causing all sorts of issues. Oil dilution is one and similar issues as my 1.5 turbo. He also said that some only had 22,000 miles.
So now, I'm looking at a possible blown head gasket, cracked head or block. It's just sitting in my driveway collecting dust while I'm still making the payment.
I bought this car because I know that this doesn't happen to Hondas. Hondas are supposed to run until your children can drive them. I'm really disappointed and frustrated.
