Hi:
I have a car that has ABS Power brakes and the pedal goes down quite a bit and the brakes do nothing. When you really strongman "leg press" against the brake pedal it bites and brakes the car, but it also mostly locks up the front wheels suddenly as well.
I had convinced myself 99% it is a brake booster failure. Now, I am not sure. I read a post that could be a Master Cylinder failure. Since replacing the booster while easy is fiddly and I have to remove things to get at it, I was a little reluctant to install a used booster I got at the junkyard if it's the master cylinder.
My experience with failed master cylinder is a locked on front brake on my motorcycle that would not release at all (tons of brake residue gunk plugged up the 'plunger' in the MC... cleaning that out thoroughly fixed that problem).
Thanks for any opinions you might shed.
The brake problem as been consistent for 6 months, and the car is either not driven at all or just into town carefully by a family member a couple times in an emergency.
(fwiw, it's a 2007 Hyundai Sonata V6, I know it's no Honda, but this forum I'm on the most and I would be pretty sure booster and MC failure symptoms should be fairly universal).
