I am working on my wife's 2012 V6 Accord Coupe Automatic. I am a long-time wrench turner but for almost a decade I have been a European-only guy, so I am not exactly super familiar with the idiosyncrasies of Honda/Acura or even Asian makes.
The car is sitting right at 59K miles and I was tasked with taking it into the dealer last to get the oil changed and the multi-point inspection.
They called me back and told me the following were badly needed:
I had them do the power steering fluid, just because I didn't want to mess with it, but the rest of those sounded too easy to pay for.
I did both filters, and was able to do the transmission fluid exchange with Genuine Honda DW-1 in about an hour, including time getting the car on ramps, finding the ATF filler bolt, and just feeling comfortable around the car. The magnet was pretty well covered with tons of gunk and metal shavings, but from other pictures and videos, it looked very similar, if not better, than others I have seen.
So, I felt pretty confident with the car and started in on the brake fluid exchange. I pulled out my Mity-Vac and sucked the reservoir completely dry. I was able to get it so empty I got almost a full 12oz. bottle of Genuine Honda Brake Fluid in the reservoir. Although this was easy and went well, I knew I had to bleed each wheel until I saw clean fluid coming out of each of the bleeders.
Here's where my frustration hit a maximum and I am just writing to figure out where I went wrong or if there is any other quicker, more efficient way to accomplish this.
Since I was doing this alone, I opted for a vacuum bleed. I read somewhere else on here that the sequence is LF, RF, RR, LR.
I started on my LF. I pulled off the rubber dust cover, cracked the bleeder open, connected some clear vinyl tubing and hooked up the Mity-Vac setup. Right from the get-go, I knew something was a-miss.
It seemed like no matter what I did, I had airbubbles entering the line from around the bleeder screw. I couldn't tell if it was entering the system from the bleeder to hose, or the bleeder screw to caliper.
I fiddled with it for almost an hour and never got clean fluid out of the caliper. I ended up hitting sunset and losing my light and pushing my tools just inside the garage door and coming in to watch the Super Bowl and write up this post.
I have a couple of questions:
Anyone else have a nightmare of a time trying to vacuum bleed their 8th gen brakes?
Second, where can I jack this thing up from the front and again from the rear so I can do two wheels at once instead of going wheel to wheel?
Any other method I should try? I really don't want to do the pedal bleed - I don't trust anyone not to let up on the pedal and suck air into the system when I have the bleeder open. I have ready the comments on the Motive Bleeder system that the cap adapter SUCKS and doesn't fit right.
What does the dealer use to do a full system fluid exchange? I want to buy that!
Thanks in advance everyone! I am looking forward to maintaining this car well over 100K miles.
Thanks again,
Brandon
- Transmission fluid drained and filled
- Power steering flushed
- Brake fluid flushed
- Both the engine air and the cabin HEPA filter changed
Thanks again,
Brandon
