1 - 7 of 7 Posts
i have a 1998 Honda Accord. i noticed recently that my brake lights are out. the one on top turns on but the ones on the side do not. i checked the bulbs and they all seem to be good. does anyone know what it could be?
Done Accordingly
Chk ur fuse....under the hood...i believe its a 20amp fuse...:thmsup:
There is also a fuse in the drivers side fuse panel (#9) that is part of the circuit.
If you have a voltmeter start checking for 12 volt power -at bulb socket, pedal switch, fuse. Where ever it goes from 12 volts to 0 volts is the problem.
I have the same problem currently on my 99. Any luck figuring it out? The third brake light works but the two lower ones do not. Both fuses are good.
1 - 7 of 7 Posts
