1 - 10 of 10 Posts
My 2012 Accord had original OEM rotors and brake pads until it developed pulsation at 45k miles. Had a panic stop on the interstate and held the brakes down in stop and go interstate travel with 30-40% pad life so not a ton of thickness for heat dissipation.
I replaced with AC Delco rotors with Akebono Pro ACT on fronts. On Rears I have had Centric 120 premium rotors with Akebono Pro ACT pads and Autozone Duralast Gold Pads and Rotors on the rear (black coated rotor). Had to switch from centric/akebono to duralast when I had a hung caliper piston on rear.
The front axle is noisy with the AC Delco Rotors and Akebono. Only I can hear it inside the cabin but there is a squeaky clean sound when brakes are cold if you let off the brakes slowly like modulate the brakes. I never noticed this noise with OEM Rotors and Pad (they just developed pulsation at 45k miles) OEM setup was extremely quiet.
I want to go back to OEM pads for quietness sake - Akebono stop much better. I know I definitely need a cross pattern machined Rotor.
I'm not sure if I should go Centric 120 rotors or go back to OEM rotors to pair with the OEM brake pads. I also noticed the OEM brake pads gave off a red dust... not sure if anyone else noticed that?
I'm afraid aftermarket rotors like Centric 120's or Duralast Golds (only coated on hat and veins) may lessen the life of OEM pads? Not sure if that's a valid worry?
The OEM rotors seem super soft - Grooved after 5 years of aggressive driving 2013-2018 and pulsation occurred after a panic stop and held brakes on stop / go interstate traffic. Or the OEM brake pads are more aggressive than Akebono Pro ACT pads - not sure?
*I've also had brembo coated rotors and akebono pro ACT on fronts and the squeaky clean sound was extremely awful with that during a cold setup - I mean if you creep off the brake pedal so slow and you get it to groan at you (when cold, first stop etc).
· BACK TO THE FUTURE!!!
TX Accord (the 950k+ mile 7th gen courier) has had great luck with the rotors and pads that he uses.
might want to send him a PM, or check out his youtube channel, for more info...
Reactions: TX Accord
I had a great experience with Centric's daily driver grade smooth painted (black) rotors front and rear with Centric ceramic pads. They were on the car for 75k miles with no pulsation until the car was totaled. My replacements for my current Accord will also be Centric.
· Prefers to shift his own gears
I used to get around 150k miles out of decent parts store rotors and lifetime pads. I switched to Powerstop Z26 pads and rotors. The rotors are cross drilled. I got around 350k miles out of the Powerstop set so I replaced them with another Powerstop set. Rockauto had a pretty good price on them.
2012 Honda Accord (EX-L V6)
Whatever you use, following the bedding procedure is key for long rotor life. Probably less important on a lighter vehicle like the Accord, but do it right and your rotors can last for a long, long time.
2009 Accord EX 3.5L V6
I've used Powerstop on both my Dart and my old Vue that I had for 15 years. It was the last set of rotors I needed. The Vue would eat rotors alive. Stock rotors were only good for about 60-80k. AC Delco and Duralast didn't last more than 30-40k. After a couple hundred K we did need to have the Powerstop rotors turned because they were slightly uneven, but they lasted several years. (Michigan is real hard on rotors)
Absolutely this.
Thank you for the info, which bed in process do you follow?
With Honda OEM was hoping to not have to bed in after swapping them out?
I've followed the same procedure since my first set of Stillen performance rotors a few decades ago. I was unable to find their instructions, but did find this which is almost exactly the same.
Bed in Procedure (febrakes.com)
· 8th Gen Believer
I'm on only my third set of OEM pads & rotors @ 162k miles. Lots of it depends on your driving.
2014 Accord Sport MSM
I replaced the OEM front pads on my '14 Accord at 30k miles right after I bought. I went with Centric blank rotors and re-used the stock pads as they had tons of life left. I'm at 62k now & brakes are smooth.
I ordered StopTech slotted rotors & already have Akebono ProAct pads ready to go. I have had the ProActs on 2 other cars & loved them.
1 - 10 of 10 Posts
