In talking with a friend who also owns a 7th gen Accord, we got on the topic of brakes. He hasn't done any service to the brakes other than a brake fluid replacement at 40k. He now has just over 100k and I am advising him to have them done by the dealer, for safety's sake. I mean it's been about 60k and his reservoir is half full. And he has no idea as to the condition of his bleeder screws.
What sayeth you? Remove the remaining fluid and fill then gravity bleed each wheel in his garage, or leave it to the dealer to deal with?
Gravity bleed with 2 jars on 2 wheels concurrently.
I gravity bled, which got more bubbles out than whatever the dealer did.
- Have a 32oz can ready. I use Valvoline from AutoZone
- "Hot lap" the car, brake many times before starting the job. This gets the brake fluid warm, easier to flow
- Use a syringe or turkey baster and suck out most of the old fluid from the reservoir
- Jack up the front end of the car and support front end, take off wheels... obviously
- Mason jar + clear hose that barely fits over the bleeder screw. I don't recall the size, I can get this when I get home. I use small zip ties that tie onto the end of the hose on the bleeder screw nipple so they don't pop off during bleeding. The hose does not need to be submerged in brake fluid already.
- Top off reservoir with new fluid. Leave the reservoir cap off and open up the bleeder screws at both front driver and front passenger side. 1/4 turn is enough unless you see nothing flowing then you need to take out the bleeder screw completely and clean up manually using a pin. Taking out the bleeder screws does not let air in, I know, I've done this.
** at any given time, do not touch the brake pedal **
- Let the fluid flow out slowly, you might think this takes forever, but this is the best bleeding method without introducing any air. Add new fluid into reservoir as you see old flows out into the jars. DO NOT LET THE RESERVOIR RUN DRY. Use a rubber mallet and tap the rear of the caliper, this helps getting additional trapped air bubbles out.
- You will see fluid in the clear hose turn from dark color to golden brown/orange. Close the bleeder screw. Do not over-tighten, but need to be rather snug. The way to tell whether it's completely closed with no leak is to roll up a small piece of paper towel and stick it into the nipple opening of the screw and see if you keep sucking fluid out.
- Move on to the rear wheels, same method. The rear will take a long while, but I let it flow for 30 to 40 minutes.
- Top off reservoir to the max line and close the reservoir cap.
Put a block of wood against the firewall so the pedal does not go all the way down and you can bleed then just fine.
If you do go to the dealer, they will likely skip this step and with an old master cylinder, it will mess up the seals going full stroke - but you won't find this out until at least a couple days later.
Then when you complain to the dealer that they ruined your master cylinder, they will say it is not their problem. They will claim coincidence since the master cylinder was working just fine after they worked on the brakes.
This is what I was most concerned with. It's easy for the dealer to cause the damage, claiming no responsibility, and hit him up for a nice additional fee. I like the idea of not touching the brake pedal even better. It's long since time he replaced his fluid.
Does he know enough about brakes, to do them himself? We don't know the answer to that question. He can clean the rust off the calipers, clean and re-lube the pins, lube the piston seal, do everything else right, and the piston could still seize up after pushing it back into the caliper. Could he change a caliper if that happens? You have to be prepared for anything when you start working on your brakes.
You can do what RacerRik said. With that method, the tube needs to be submerged into the mason jar with brake fluid already. Pump steady and and don't go to the floor, the piece of wood stops pedal from travelling in unknown territory. The problem with doing this method yourself is that you can't see the fluid flow in action while pumping, you need another person. If you have another person, then might as well do the 2-person method, pump, open, close, lift, then repeat.
This is the way I've bled my own brakes, by myself, using a square of 2x4 to keep it off the floor, (no full-stroke) and a cinder block to keep the brake pedal depressed. Open, close, remove block. And I have always kept the old brake fluid in the mayo jar to ensure no air finds it's way up.
The Motive power bleeder leaks air with their cap style, it does not create a good vacuum. The Honda brake reservoir cap is different than all the other ones. Unless Motive fixed this. I didn't get one because of this problem.
gravity bleeding is free, no special bleeder device required. Honda did vacuum bleeding years ago, let air in, just saying.
I met my friend at the local Honda dealer, Cramer of Venice. I explained what I would like them to NOT do, i.e. use the pedal to generate pressure. They assured me they were well aware of old MC's and the problems caused by full stroking the pedal. They had his car up, removed the old fluid (which they weren't going to do until I asked politely - they were gonna run that crap through the lines - SMH) used a bottle with new fluid to keep the MC full and vacuum bled the four wheels in 25 minutes. Total charge $70. Well worth it in my opinion.
On and by the way the brake pedal is much improved. Tech said there was a ton of sediment in the reservoir. And to think they wanted to pull that through the lines. Ugh.
Most times I use a mity-vac (now have a craftsman), to vacuum the brake fluid out through the bleeder at each wheel. I push the brake pedal down a little, just to get the fluid flowing. Letting up on the brake pedal doesn't suck any air in, as long as you keep vacuum pressure on it. A tight fitting hose is a must, but I can do this without any help. Yes, the vacuum pump will give your hands a workout, but what's wrong with that? If I have to change a caliper or replace a brake line, I will get my father to help with the two person pedal pumping method.
I don't see why you can't do all 4 at the same time if you have 2 sets of jack stands and aren't afraid of the front end moving if you can jack up and secure the rear end while the front end is already on jack stands, this is my biggest concern. I don't have a lift obviously. You need to be extra careful with the the fluid in the reservoir because it'll drop faster when all 4 are open at the same time.
I pull all the old brake fluid out of the reservoir, pull the little screen out and clean it, pour new brake fluid in, then vacuum it through to each caliper till it comes out clean. Doesn't take long to get clean fluid through.
The reason I don't use a vacuum bleeder is because I actually called Mityvac years ago asking them about it. They told me that "you might have to modulate the ABS module to get the fluid out of the ABS unit." I thought the guy didn't know what he was talking about so I never went the vacuum route.
Then I did research on the Motive vacuum bleeder and discovered the vacuum seal problem with their cap design, so I didn't get that either.
I am single, living on my own, so gravity bleeding it is.
I punch through the cap of a water bottle and stick a hose down in the bottle, so it's submerged in brake fluid. That is my one man bleed tool, LOL. The gravity of the fluid in the bottle, is greater than the suction that attempts to pull it up into the caliper, when you are pumping the brake. So no air or back-flow.
Also have a large hospital syringe with 1 ft of clear hose attached to it. I stick the hose deep down in the brake reservoir and suck out all the old fluid before I begin.
If I'm doing a brake job but not replacing the fluid, I open the bleeder nipple when compressing the caliper piston. The caliper is where the fluid really gets heated, so I don't like to push that tortured fluid back into the sytem.
Kinda thought the idea of pushing the junk "back" into the lines was not a good idea. Maybe after doing the drain, then back flush to push air into reservoir? dunno. It's always worked as you all have stated for years of brake bleeding and flush, but it was an interesting idea anyway.
Interesting thread; I had't been aware you could drain without pumping. I have more time than helpers, so this sounds good to me.
Regarding what's in the reservoir, if I'm understanding correctly, there's an opportunity to remove most of it with a syringe+hose or whatever, and even clean the screen prior to draining. Just looked through the records of the car I picked up and don't see that it's ever been done.
Draining the old fluid is probably the most important part. And would you believe the dealer was going to pull that old fluid through the lines. I asked them before committing to have the BF replaced. I was concerned with the MC and having the pedal pushed to the floor. They used a vacuum to pull the fluid at the wheel. All in all I think they're a decent Honda dealer. I've seen some absolute crooks i.e. Plaza Honda Brooklyn NY and Staten Island Honda NY. It was because of these dealers that I decided to commit to DIY. Since there are two '03 V6's in the family, I learn on one and master on the other. Usually my car is the guinea pig.
I have been working on cars for 39 years but as I became busy and a little more affluent I started paying people but now after inspecting work and speaking with meachanics and arguing at the Stealership I have decided to do my own maintenance such as brakes and oil changes.
I go online and watched YouTube videos of guys doing their disc brakes. I keep seeing them take a C-clamp and depress the piston or pistons to fitt them over the new pads.
2 things I am seeing them do incorrectly.
1. Never put the clamp directly on the piston skirt because you can gall it, always use an old brake pad as a backing to press evenly and firmly.
2. and most importantly open the bleeders so you do not push nastly old brake fluid with potential solids and impurities with water back into the ABS system.
open the bleeders and keep flushing each brake until nice clean juice comes out. use a bottle with the hose touching the bottom so you dont draw air back into the system. This precaution can save you hundreds if not possibly thousands to redo and clean out your ABS.
125.9K members
