Bad 12V battery? I had a bad 12V a couple of years ago that would be completely dead sometimes, but then would be able to start the car without hesitation at others.
What's a factory program car?
I really appreciate everyone’s prompt feedback. I just took my wife’s car back to her and I’m walking back to mine. Hopefully the car will start again. I’m going to head out to the Honda dealership. I will make sure to follow up on this post hopefully, this thread will benefit someone else.
Unfortunately, a factory program car is not a certified pre-owned car. If it were a factory certified pre-owned car, it would be sold as, and called a factory certified pre-owned car. I've been in this business going on 40 years and a "program car" is dealership code for "rental". That's right, the OP got stuck with a rental.Sorry. I might be showing my age. It’s an old-school term for a certified pre-owned warranties automobile.
rkellis, thanks very much for following through on this and letting us all know what the problem was. Many times on this forum people describe problems, ask for help, get lots of feedback and suggestions, and then never show up again. Your posts are a great reminder to check the simple things first--like loose battery cables. Cheers!The culprit: an improperly fastened battery terminal connection. Apparently a service technician had not tightened the terminal clamp screw. It was completely loose. The 12 volt battery is 11 months old and while the technician agreed and that sometimes the batteries are prone to early failure, this one was tested and checked out. Hopefully this is the end of this. Certainly not the type of experience you want to have on a car you only owned for four days. Lol.
A Carfax report will confirm/deny that. A rental car is explicitly shown as rental car on the report.Unfortunately, a factory program car is not a certified pre-owned car. If it were a factory certified pre-owned car, it would be sold as, and called a factory certified pre-owned car. I've been in this business going on 40 years and a "program car" is dealership code for "rental". That's right, the OP got stuck with a rental.
