I have been searching this forum high and low. Working my way through the 3000+ post lighting thread and I have been unable to find instructions on how to retrofit V6 headlights in an I4.
I am 99% sure the HI & Low Beam and turn signal are the same. And I know I can just pull the fuse to disable the OEM high beam DRL. So I just need the plug that connects to the LED strip and wire it to a switched power source and I need to know what wire gets the power and how the LEDs are signaled to dim when the headlights are on.
I found the part number for the plug --> 04321-S0X-305
Does it have wires coming out of it? What wire gets what voltage?
