1 - 1 of 1 Posts
Vendor
MyAirbags clears all soft codes and hard codes that are stored after the vehicle was in an accident.
Your handheld scanner can't do it all.
There are two types of codes:
  1. Soft Codes
  2. Hard Codes
Yes, most scanners can clear soft codes after the problem is solved. These are codes that indicate a fault with an SRS system part/component such as
  • driver airbag codes
  • seat belt codes
  • impact sensor codes
No, scanners cannot clear these codes. These codes are stored after a vehicle accident and are also known as crash data. Also, these codes are hardware issue codes.
Hard Codes require professional reset services like us. Our MyAirbags' IPC-Certified technicians have already reset millions of modules for our satisfied customers!
Start Your Airbag Module Reset Order Today!
1 - 1 of 1 Posts
