1 - 18 of 18 Posts
I have an 06 accord 4 cylinder. It takes a 51R- S .I was wondering if I can put a 51R- E battery in it without it messing anything up.
What exactly do you mean "without messing anything up"?
Are you asking if it will fit without modification?
Are you asking if the battery will be of sufficient power/amps/CCA for your needs?
Please provide a link to the 51R-E battery
Yes I was wondering will it needs mods to work or can I just throw it in and it work. And will it power the 06 enough or will it over power it. I dont want to fry anything.
Actually I just found I can put a group 35 with 640 cca in. I just need the bigger ground wire thats used in the 6 cylinder. It's bigger and its not as expensive as the weak one that's supposed to go in it.
There is no such thing as "over powering" a 12V DC system with a larger 12V automobile battery. It may hold more charge, and that's a good thing, it may provide more amperage for cranking, and that's a good thing. If it fits and can be properly connected and secured, that's all there is to it. I really wish I had thought of putting in a larger battery on the '03.
A larger ground cable is a good thing too ... but if the postive going to the starter is also not "big" then you're not getting much benefit from the larger ground. (Look up "big 3" battery cable threads anywhere). For such I'd go for the ground + starter cable with less emphasis on the alternator to battery cable.
Premium Member
Some of the 51 series may be too tall...check the dimensions off a spec sheet if possible and then measure your dimensions to be sure.
What do the -S and -E designations mean? I've never seen that before when it comes to the BCI 51R battery.
In the USA, S means it is for use in the Southern part of the USA as the battery will perform better in the outside heat. N means for use in the North as they perform better in the cold, never heard of E though.
@KW2004Accord do you have a reference for this N/S designation?
- about half way down the page, paragraph starting with "Some flooded batteries are offered in N & S versions".
Good article. Thanks.
There's no mention of a "N" or "S" designator in the article, nor anything about how the battery is marked other than manufactured date. It does mention that batteries sold further north emphasize higher CCA wheras batteries sold further south have higher electrolyte to Pb ratios. It's still interesting to know. Also the article goes on about AGM being better in northern use so when my car needs a new batt I'll be looking into that. By then there may be progress in Li-ion packs for main batteries too.
Reactions: RickBlaine
Put in a 24. Way better battery and it's about $20 cheaper
Why a 24 instead of the typical 35 from the V6?
If you remove the underside tray and the OEM enclosure, there are a great number of other battery sizes that can fit into the 4 cylinder. The sizes are more common and cheaper as noted above. There is a long thread in this forum that covers the whole thing. I have a 24 or 75 in mine (can't remember which). More CCA and fits fine with no mods other than lift and enclosure removal.
Maybe that's what I meant. Ya the V6 battery. I was thinking it was a 24.
Reactions: derass
How much do you all pay for batteries? I got the one for my 07 4 cylinder for 87 bucks out the door with that 100 month warranty from a Honda dealer I worked at that my employee discount still works at. No issues so far. Going 4 years no hiccups. I think they want like 132 installed after tax. Not bad considering advance auto parts charges 164.99 plus tax for the same thing with 3 year warranty.
I always buy from Walmart. They are the cheapest, have 5 year warranties, are everywhere, and are the easiest to swap if you need to.
I put a Bosch 24F battery from Pep Boys in my 2006 VP 4-cylinder. Don't use the plastic tray, the battery just sits on the metal mount underneath and I purchased longer j-hooks and battery holder.
Yes to the above post, exactly what I did although I was able to get my existing hooks and hold down to work for me (tight fit).
1 - 18 of 18 Posts
